4l60 downshifts late.
During the engine swap, the trans slipped off the jack stands. The rear trans mount saved it from hitting the floor, and didn't appear to cause any damage. I replaced the mount and inspected the fluid lines and wiring, but found no damage.
Is this slow/late downshift conducive of an underlying issue?
No other problems with the trans. Fluid is bright pink and clean, and it upshifts great.
This is the stock trans in my 2003 silverado.
Thanks
The only way to tell if the trans is acting up is to use a scanner that can log the shift commands to verify that the trans is immediately responding to them.
I suspect the problem is in the tune. Was the PCM retuned or replaced during the engine swap?
If I wanted to pull the tune file and have someone else take a look at it, what software/hardware would I need to purchase? It was tuned with EFI live and I know the file is unlocked.
Is there one software that can edit tunes and perform the scans you mentioned?
I suspect that 70% here use HP Tuners. Expensive at $650, but that is what it is.
A simple scanner that you can borrow free from many chain auto stores might still be useful. It would let you check that the TPS and MAP sensors are working properly.
I assume the speedometer is reading the correct values.
Some general-purpose scanner will show the commanded gear position, some do not.
