lock up issue
Old Mar 1, 2015 | 07:41 PM
1-87 chevy's Avatar
Default lock up issue
hello , I have a 4l60e with a fresh rebuild and iam having problems with the lock up not engaging .the converter was cut and gone thru by a very reputable company before it was put in. I have dropped the pan and replaced the harness, pwm solenoid,valve body,
I have activated the tcc manually with hp tuners, I can hear them click on and off and nothing ,still doesn't work .
is there any where else I can look that might solve this problem?
thanks in advance
Old Mar 2, 2015 | 03:39 PM
bbond105's Avatar
Have you done anything with the TCC solenoid?
Old Mar 2, 2015 | 08:23 PM
1-87 chevy's Avatar
yes replaced it with the harness
Old Mar 4, 2015 | 01:01 PM
mrvedit's Avatar
Moderator
Did you remember the O-ring on the input shaft?
Old Mar 4, 2015 | 08:39 PM
1-87 chevy's Avatar
yes o ring is on input shaft
the only thing that was not on this tranny is the pump since I was broke ,that what happened initially.
Old Mar 4, 2015 | 10:06 PM
mrvedit's Avatar
Moderator
Please explain, I don't understand your 2nd line. (Better - edit the post)
I suspect you are saying you replaced the pump. If yes, what year is the trans, is it a 298mm or 300mm input shaft 4L60E. (Does it have a bolt hole in 12 O'Clock position). What kind of pump was installed - a PWM or non-PWM?
