6L80E for C6 Z06
thanks.
It appears that the C6 started with a 4L60E and later years have the 6L80E.
Due to the much larger size of the 6L80E and the tight fit in any Vette, many changes would likely have to me made. The main ECM likely needs to be changed and the properly trans wiring harness installed.
I'm just guessing. Perhaps someone else knows more details, but likely the various Vette forums will have an answer.
I will also guess that it would likely be cheaper to sell your car and buy a newer one with with the 6L80E. Also, have you driven a C6 with a 6L80E just to be sure it is worth it?
