shifting
Old Mar 25, 2015 | 11:18 PM
SpeedFreak7's Avatar
Default shifting
Alright, my 98 ws6 is finally alive! engine starts right up and car is drivable. even all electronics are functioning. it freaking jolts you back into your seat!
Now to the issue. 1st 2nd and into 3rd gear are perfect and smooth but 3rd into 4th, 3rd gear seems to wine longer than it should take, like its delayed going into 4th, it hits 6,000rmps before shifting to next gear, doesnt seem right.note, this is W.O.T. or at least 3/4 throttle. its a 4l60e with a speed shift kit. my guess is one of the 6 clutches that engages 4th is probably slightly jammed up delaying shifting or something like that. Am i thinking too much into the wining and its supposed to be like that? Please someone with tranny knowledge help me. the car has about 430+hp with 3.73 gears with a speed shift kit 4l60e
Old Mar 26, 2015 | 04:09 PM
mrvedit's Avatar
Moderator
The "6 clutches" refers to the 3/4 clutch which is engaged equally in 3rd and 4th gear. So that is not your problem.
When shifting from 3rd to 4th, only the band engages.
If the 1-2 shift is good, then the band is good.
However there is a separate servo piston for 4th gear. A cracked piston or leaking seal on it could result in a slow shift.
Shifting is completely controlled by the PCM. Therefore the first step is to determine if the delay is due to the PCM/tune or the trans itself. A good scanner, like what a trans shop has, can be used to command shifts. A test drive with a friend/mechanic running the scanner and commanding the 3-4 shift could help determine the problem.
I have no idea what a "speed shift kit 4L60E" is. Please give us more info or a link.
Old Apr 1, 2015 | 10:02 AM
Default trany
http://www.ebay.com/itm/like/261170348372?lpid=82&chn=ps, here's a link about the speed shift kits. And im gonna see if the mechanic who is doing the trany flush can do a quick scan for the 3rd and forth. hopefully the flush will take care of it
Old Apr 1, 2015 | 10:14 AM
mrvedit's Avatar
Moderator
Many of us here are very familiar with the Transgo HD2 kit. Just never had it called a "speed shift kit".
Assuming the problem did not exist before installation of the HD2 shift kit, I would first suspect a servo problem, e.g. backwards 4th piston or torn seal. Next I would suspect a torn separator plate gasket or a mistake in updating the valve body.
Good luck and keep us posted.
Old Apr 1, 2015 | 01:06 PM
bbond105's Avatar
I don't think this trans will shift into 4 gear under W.O.T. You would have to be going pretty fast for that shift.
Old Apr 1, 2015 | 01:52 PM
mrvedit's Avatar
Moderator
Originally Posted by bbond105
I don't think this trans will shift into 4 gear under W.O.T. You wound have to be going pretty fast for that shift.
Ahhh, yes of course.
You read the OP's "wine longer" as "wind longer"; I read it as making noise and possibly slipping.
Old Apr 1, 2015 | 02:42 PM
bbond105's Avatar
Will it shift into 4 gear under normal driving conditions?
