noise going into gear.
When I put it in to gear it sounds like the tranny is shifting and touching something. Its a slight clunk. I feel like its an external noise. It also makes the nosie on the occasional shift. Though it is hard to replicate the noise during shifts. Its a 4l60e
You will be much happier with the OEM trans mount.
The OEM mount will also have a bit of "give" to make the torque arm mounting less critical.
