4l80e wiring
Old Apr 15, 2015 | 06:30 PM
protestthehero's Avatar
Default 4l80e wiring
Hey guys I've got a couple questions
So I'm doing a 370lq9/4l80e 411pcm swap into my 91 camaro. I had a harness built by Shannon Taylor from sloppy mechanics and it wasn't designed for a 80e, but for a th400. Well now its an 80e build and I need to pin my connector. The issue is it's a 98 80e and the bulkhead connector is different than the model showing the 60e to 80e swap. The pins are different. Plus I need to pin in a vss into the 22 and 23 right? This whole thing has been a massive headache and I could use some help of what pins go where and how to do it. Btw its running on the 80e segment not the 60. I'm not messing with any relays.
Thanks.
Old Apr 16, 2015 | 11:49 AM
bbond105's Avatar
Try this web site.
http://www.lt1swap.com/index.htm
