No idle after 4l80e swap.
Old May 8, 2015 | 07:27 PM
bbond105's Avatar
Sorry to see your trans go so wrong. Are you going to try to have it tig welded or just going to replace the case? Once you go back together I would hook up the pressure gauge and keep an eye out for very high pressures.
Old May 8, 2015 | 10:32 PM
Jose93z28's Avatar
Thanks guys, I will either replace the case, Mrvedit thanks for the PM, or get another tranny and just run as is with the exeption of the circle d stall converter and see how it does, Im almost scared to redo the shift kit again since I feel that's where my problem might have starded to begin with.
