Error 4L70E Supermatic GEN2 please help
Old May 27, 2015 | 12:48 AM
stebasha's Avatar
Default Error 4L70E Supermatic GEN2 please help
Hello, I have a problem, and the problem with the program setup and calibration, which was on the disk. I already installed on the laptop 4, but the effect is the one I turn the program starts to read the firmware with TKI, at the end of an error run-time error 13 type missmatch. then after you click OK, climbs two more errors and the program closes, version 4.1.2 software worth.
I bought a set of online Jegs.com Chevrolet Performance LS376 / 525HP Connect & Cruise Powertrain System, I have a problem with the program for transmission supermatic, startup gives error 13 type mismatch, as well as error codes 401, 403. Next, the program closes version software 4.1.2, could you throw fresher version and what to do? (Invoice 847445070214)
I tested already on 6 computers. Software is installed 4.1.2. Errors occur when information is read from the controller after connecting with him. Errors such as 13 type mismatch associated with the VBS, ie with the program itself. Please check again.
"Runtime Error '401': Can't show non-modal form when modal form is displayed." and Runtime Erorr '13' type missmatch
Please HELP ME (((
Old May 27, 2015 | 08:24 AM
mrvedit's Avatar
Moderator
OP: You are welcome to post this as a duplicate thread in the PCM-Tuning section. Depending upon where people help you (hopefully someone can), I can merge the threads later.
Old May 27, 2015 | 11:50 PM
zgp's Avatar
zgp
Please HELP ME (((
PCS is the supplier of those controls, try their tech support.
https://www.powertraincontrolsolutions.com/
Old May 27, 2015 | 11:54 PM
stebasha's Avatar
Trans controller 19302405 is the GEN2 controller, not powertrain.
Old May 28, 2015 | 10:38 PM
zgp's Avatar
zgp
Ok, you asked for help, I worked with this program for many years. PCS is the supplier of that one also...
https://www.powertraincontrolsolutio...on_Controller/
Old Jun 1, 2015 | 12:31 AM
stebasha's Avatar
ok thanks, i write message to tech support e-mail
Old Jul 12, 2015 | 11:38 PM
stebasha's Avatar
hello support not me help (
"Sorry to hear about your software issues. Try giving GM tech support a call 866-453-4123 they should be able to help you out."
Have anybody software ? maybe bad CD ? my e-mail scts.sakh@gmail.com please send me file
