Converter suggestions for powerglide
Old Jun 5, 2015 | 10:54 AM
M0N0L1TH's Avatar
Default Converter suggestions for powerglide
Looking to buy a converter for my glide. 5.3 carbed with ljms cam and eBay headers, gonna spray 300 through it. Powerflide is a PTC with a pro brake. Running 275 tires with a 373 gear.
What do you guys suggest I run? Not sure what stall I need.
Old Jun 5, 2015 | 02:55 PM
Circle-D_Brian's Avatar
You will most likely be doing a 245mm diameter converter here. Though there are lots of companies that can make a power glide converter, we would do something that uses the 5.3 flexplate and stabs in the PG transmission without the need for any spacers or pilot extenders. Very seamless install. There's a few more details necessary to spec a converter. If you have the time, fill out the ask chris form in my sig and we can nail down a stall speed.
-Brian
