4L60E shift problems
Old Jun 17, 2015 | 08:26 PM
simman22's Avatar
Default 4L60E shift problems
After hours of searching I figured I would just ask here since I couldn't find an answered post on someone with the same problem. I swapped my old 2002 4.3 and a 1997 4l60e (rebuilt) into a 1981 C10. I got all of the engine harness, engine mounted, and PCM changes made.
It runs beautifully but when you put it in drive it stays in second. You can manually shift it down to first but other than that it stays in second (park, reverse, and neutral work correctly). On HPTuners I can command 1,2,3,4 and TCC lock without an issue. The only code I am getting is P1810 sometimes. When the code isn't present it still does the same thing. So any help would be greatly appreciated.
Old Jun 18, 2015 | 04:39 PM
simman22's Avatar
Internal pressure manifold was the culprit, changed it and all is good.
Old Jun 18, 2015 | 08:33 PM
bbond105's Avatar
Those things can create some strange problems.
Old Jun 22, 2015 | 08:28 PM
iceburgh's Avatar
explain more please....having the same issues but don't know what to do with internal pressure .
I have the intune and need to get the tranny working
Old Jun 22, 2015 | 10:34 PM
coryforsenate's Avatar
If you think it might be a bad manifold pressure switch, it's a cheap part and only requires a pan drop to replace. It might be worth giving it a shot even if you're not sure it's the problem at $30 for the MPS, AC Delco part #24215111 for the 4l60e.
Old Jun 23, 2015 | 03:55 PM
bbond105's Avatar
The way you check for a faulty manifold pressure switch is with some type of scan tool. With the engine running you place the shifter in reverse, drive, 3rd, 2nd and low and check the scanner to make sure the manifold pressure switch scanner readings coincide with the whatever position the shifter is in. If they don’t match up then most likely the manifold pressure switch is defective.
Old Aug 30, 2015 | 11:32 AM
simman22's Avatar
To go off of that (for anyone in the furture with this problem), I was able to command everything with HPTuners and it worked fine.
