95 4l60e
Old Jun 20, 2015 | 05:35 PM
kmk7110's Avatar
Default 95 4l60e
My girlfriend and I recently acquired a 1995 z28 lt1 4l60e T-Top. It was free and I'm currently trying to piece things back together. It was torn apart and left in her moms garage. It was apart for about 10 years we assume, 7 or 8 in her garage. It was an optispark problem. The previous owner took it apart to the distributor and had a new one already install. Motor runs great after putting stuff back together.
Well long story short the trans fluid was burnt badly and blackened. When its warm it will slip badly. We flushed the fluid It will not want to shift into gear easily either. I've been looking to either replace the trans or repair the issue. I'm looking used instead of rebuilt and since GM used so many different variations of the same transmission I'm lost on what will and wont work. I've found a 96 trans out of a TA with a shift kit in it. Will this bolt up and go no issues? I know I cant really go backwards because of the EPC I think. Thanks in advance for assistance.
Old Jun 20, 2015 | 06:58 PM
coryforsenate's Avatar
I think I recall some big differences between '95 and' 96, like PWM, pump, and valve body.
Old Jun 20, 2015 | 10:45 PM
kmk7110's Avatar
Ok thank you.
Old Jun 21, 2015 | 02:28 AM
Originally Posted by kmk7110
Ok thank you.
I'd let one of the builders or experienced members comment too. I've only rebuilt one 4l60e. But I'm pretty sure that I recall when doing research for my rebuild that in '96 those were the big changes from '95.
Old Jun 24, 2015 | 08:35 PM
mrvedit's Avatar
Moderator
Yup. '94 and '95 are each unique years that only work with the PCM from the same year.
I call the '94 the "alpha test" and '95 the "beta test" years. '96 is the first stable year as '96 through '05 (and sometimes later) are all electrically identical.
