4l80 shifting issues
Old Jun 21, 2015 | 07:51 PM
jimmyg's Avatar
Default 4l80 shifting issues
Ok so I had a local shop rebuild my 4l80 and install a transgo2 kit. After 1000 miles something is just off the shifts are soft even if I max out line pressure. Doesn't really make a difference . Changed controllers same ****. line pressure seemed low what could cause this? Cross leak? Epc ? Used to shift nice and firm. any idea? Any help is apprec
Old Jun 21, 2015 | 08:29 PM
Ferocity02's Avatar
DId they drill out the spacer plate at all? Higher pressure wont help if the holes in the plate are too small.
Old Jun 21, 2015 | 08:43 PM
jimmyg's Avatar
I asked him that and he said he did . What would cause low pressure? What would leak?
Old Jun 22, 2015 | 06:27 AM
JRENIGAR's Avatar
Since it originally worked great Id say maybe the vb bolts or accumulator bolts might have worked themselves loose.
Old Jun 22, 2015 | 07:07 PM
jimmyg's Avatar
I'm hoping it is something easy . I just wish I had the knowledge to fix it my self.its kind of hard to go back on the guy because the trans does work.
