8L90 going to be available?
And yes, at some point not too far from now, 8l90's will start to pop up for the aftermarket, but they are massive. From what I have seen when people swap the 6spd autos in, they usually need to chop the floor pans up. It would only be worse with an 8spd. They will be expensive, and from all I hear about the 6spds, they are not as strong as something like a 4l80, even if they are dubbed 6l90 (the "90" should indicate higher strength).
Aren't the 4L60E and 4L80E still being made? GM sells "new" ones with the Connect&Cruise packages.
Chris
Sorry, but you are overlooking how complex cars have gotten in recent years. Heck, in modern cars several computers are required to turn the headlights on. It probably takes 4 computers for the paddles to connect to a trans and hundreds of not thousands of functions need to be implemented for a "manual" shift to occur. I would guess that the 8L80 has 10x the computer complexity of a 6L80.
Chris
