2002 silverado 4.8 wont move. Clicking noise
Okay guess there isnt much more i can ask without pulling trans. I started today. Got exhaust loose, 02 sensors unplugged, battery disconnected. Then went to drop crossmember and forgot to support trans and do a couple things i forgot i read i need to do first. But getting there slowly but shortly. I will post updates and questions. i work monday-thur 10-12 hr days and weekends i see my gf/son so i just try and work it in. Also i will note when i dropped pan i didnt see any metal flakes but nothings for sure. Also retested after jacking up front and atf level was lower and didnt change cold or running. But i figure i haveto drop trans and if pump is broken i will be able to see. Is there a way if the pumps broken i couldnt see?
