4L60E 04 gto
Old Aug 30, 2015 | 08:46 PM
Saddoris8's Avatar
Default 4L60E 04 gto
I just had my trans completely rebuilt. new clutchs and converter. before it was making a screeching noise at wot when shifting.. I broke the freshly rebuilt trans in for a few hundred miles and did a pull to find out that it is still doing the same thing as before. its only at 58k miles. any help would be awesome.
Old Aug 30, 2015 | 09:11 PM
clinebarger's Avatar
Screeching at high RPM's could be a drive belt issue...
Old Aug 30, 2015 | 09:33 PM
Saddoris8's Avatar
but it also doesn't like to shift. shifts very awkwardly
Old Aug 31, 2015 | 08:47 AM
mrvedit's Avatar
Moderator
Shifts cause a sudden change in engine RPM; the accessories such as alternator, PS pump, water pump have momentum and resist the change in RPM and can cause the serpentine belt to slip causing the screech. Try a new quality belt (Goodyear, Yates; skip the cheap no-brand belts.)
To diagnose many trans problem it is very useful to connect a pressure gauge, drive around with it and reports its readings. Even just the readings in Park, Reverse and Drive are very useful.
Old Aug 31, 2015 | 08:35 PM
Saddoris8's Avatar
you are the man. makes complete sense now. This has been haunting me for 6 months now.
