using jakes manual controller with hd2
Old Oct 5, 2015 | 02:26 PM
toughy v8's Avatar
Default using jakes manual controller with hd2
As the title says. I'm a bit concerned about using both together as there is no control over line pressure.
Old Oct 5, 2015 | 05:48 PM
jakeshoe's Avatar
It will work fine.
If you want line pressure control, you can use TransGos vacuum modulator kit.
Depending on the application, fixed line pressure works well.
Old Oct 6, 2015 | 08:10 AM
toughy v8's Avatar
It's for 90%street/10%strip.
Old Oct 6, 2015 | 11:43 AM
jakeshoe's Avatar
Application depends on HP, etc.
1000 HP street needs fixed pressure, 400 HP strip doesn't...
Old Oct 6, 2015 | 01:15 PM
mrvedit's Avatar
Moderator
I'm inclined to ask why you are using a manual controller.
If you have a carb'ed engine and no PCM, I fully understand.
However, often people have incorrect assumptions of what can and cannot be done with a properly/custom tuned PCM.
