suggestion's on a torque converter
In contrast a TCI 3600 (a cheap factory modded converter) would barely move below 2500 and I hated it for street driving.
I have used 4 different converters in the past 5 years:
1. TCI 2800 - nice for street driving, but bogged the cam'd engine under high throttle.
2. TCI 3600 - so loose on the street, I went back to the TCI 2800.
3. Yank SS 3600 - Excellent on the street, nice and tight.
4. CircleD 3600 triple disk - Also excellent on the street, nice and tight; indistinguishable for the SS3600.
Sure, $750 for a CircleD or Yank might be a budget buster, but everyone that buys one then loves it and regrets having wasted their money on their previous cheap converter.
Long story short, Greg took care of me after a member sold me a hosed 3600. I called Greg and told him the story and he basically built me a new 3800 with a free restall and warranty for no extra charge.
I have sent him some business for what he did and will continue too...Greg did not have to do what he did, top notch customer service Imo!
Good luck with it, and if you remember, give us an update after running it for a while.
op I would either say screw it and get a good budget 3200 converter from the big 3 and be content with it. the next option would be buying a used billet one but I understand your concerns there. other than that you could hold off a bit and save for what you want which is usually what I do in most cases.
Considering we use the EXACT same kit as the others you cited in your post and build principles, you truly haven't seen our product. We offer only billet converters for LS cars and again use the same core, and kit components as the others.
We USED to sell a more economical converter for bolt on cars, but haven't done so for about two years. They were great for bolt on cars, but too many people pushed them WAY too hard in turbo and heavy NOS applications. Rather than get a bad rap for this, we elected to stop selling them altogether....
Revmax has lots of fans on this forum.
If you really want a 3600 stall then you sort of have to go billet. The reason being is that to increase stall speed you have to change blade angles and other things inside the converter, there comes a point where that can only be done so much before the design becomes inefficient. 3200 seems to be the cutoff line with modded factory budget converters, they're good units but companies usually limit them to 3000-3200 because after that the design is inefficient. Above that it takes a "new" design aka the billet series in order to make the converter efficient.
With that said any of the companies FTI Yank Circle D etc are great options. I do feel circle d is a little more on the expensive side seeing as they used to be priced right with yank and FTI but have since raised prices. I would honestly call all the companies and go with what you feel best. You can't lose on any of them. Greg at FTI is a great guy and has built some of the fastest 4l60e converters.
