0 mile rebuilt 4l60 issue
Old Nov 22, 2015 | 11:54 AM
CGCBandit's Avatar
Default 0 mile rebuilt 4l60 issue
Hey all, this is in a 99 Sierra. Freshly rebuilt(bought kit from 4l60/700r4.com) New clutches, sunshell, included shift kit etc. Problem we're having is reverse is slipping horribly. It goes into reverse but truck feels like it has a 5k stall converter lol. All forward gears seem to work well other than a slight vibration at times in top of 1st and second.
Hoping it's maybe just something in the valvebody, need some suggestions on what to look for before tearing it all back down again
Old Nov 22, 2015 | 07:56 PM
clinebarger's Avatar
Reverse oil comes directly off the Manual Valve, Nothing in the Valve Body itself will cause a no reverse condition. Leaving the 3 8mm headed bolts loose on the Support Plate right behind the valve body will cause a slipping reverse.
Now the real question is.....Is it Slipping or Binding?? Does it move in slow Reverse? Or does in load up & not move?
Old Nov 22, 2015 | 09:39 PM
coryforsenate's Avatar
clinebarger, why does those 3 bolts being loose result in a slipping reverse? Fluid leak?
Old Nov 22, 2015 | 10:10 PM
The Lo/Reverse Clutch feed is right under the Support Plate/Separator Plate, Depending on how loose they are the symptoms can vary from a slow hot reverse, a Shutter or Slipping.
Old Nov 23, 2015 | 01:35 AM
Thank you for the explanation. Opening my GM tech manual, yup. There's the Lo/Reverse feed right by the three 8mm bolts.
Old Nov 23, 2015 | 10:31 AM
CGCBandit's Avatar
Thanks for the reply I'll have to take a look at that first. Hopefully that's all it is.
Reverse engages and the truck will kinda back up on level ground, but give it any throttle up an incline etc it shudders and slips bad.
Old Nov 25, 2015 | 07:39 PM
mrvedit's Avatar
Moderator
Another possibility is that one of the teflon rings on the stator shaft got torn on final assembly. And/or the inside of the reverse drum is badly worn; this is where the teflon rings ride. Was the reverse drum replaced?
Old Nov 26, 2015 | 04:57 AM
CGCBandit's Avatar
Reverse drum is original, I haven't had time to look into this yet with work and the holiday. Hoping next week to bring it in and look at everything.
Old Dec 13, 2015 | 10:33 AM
CGCBandit's Avatar
update,
Finally got around to dropping the pan, it was those bolts on the support plate. Trans is working great now.
Old Dec 13, 2015 | 11:18 AM
mrvedit's Avatar
Moderator
Great to hear!
Thank you for updating the thread. And thanks to clinebarger for sharing his extensive experience and nailing it on the (bolt)head.
Old Dec 15, 2015 | 05:28 PM
CGCBandit's Avatar
Great to hear!
Exactly, gotta love this forum. People actually give some advice when needed
