Superior Shift Reprogramming Kit K4L60E-L-V
Old Jan 8, 2016 | 07:02 PM
Cyrperformance's Avatar
Default Superior Shift Reprogramming Kit K4L60E-L-V
I am in desperate need of the instructions for this kit and hoping there is someone here who may have them. Mine are lost or gone and I am reinstalling the valve body but don't exactly remember which spring goes where and where each check-ball goes (green plastic and steel). Please help and thanks.
Old Jan 8, 2016 | 07:24 PM
coryforsenate's Avatar
Have you tried emailing the company for a pdf of the instructions?
Old Jan 8, 2016 | 07:39 PM
Since the beginning of last week and there are none online I can find.
Old Jan 8, 2016 | 10:24 PM
mrvedit's Avatar
Moderator
While the Transgo kit is surely different, these directions will at least show you where the check ***** go, and more importantly, where the different length VB bolts go:
https://ls1tech.com/forums/automatic...questions.html
Old Jan 8, 2016 | 11:32 PM
Thank you for that but the Superior has 2 check ***** in the case and I need the spring color locations as well. I have instructions for every other kit I have done with the exception of this one. I normally use the Transgo but this kit came in a rebuild kit so it was used.
