4l80e no reverse
Drop the pan and fix your manual valve and linkage.
I dual fed the directs internally, and left out the 3rd gear check ball(#8 in ATSG manual).
Reverse seems a little slow to engage, takes a few seconds but once it grabs it seems to hold. I read its due to the dual feeding but if i take out the #9 reverse check ball that will help. Can anyone confirm this ? I'm going to drop the pan during the week to check the fluid, make sure everything is good.
How is the 2-3 shift with no 3rd checkball in there? In a truck that might be a pretty heavy shift...
The 2-3 shift isn't bad at all, no worst then with the old separator plate that I drilled out per the shift kit instructions. I didn't drill out the #3 hole, only removed the checkball. So I am running with 6 check ***** and runs good. Tomorrow will be a good day of driving, going to break it in some. Thinking 50miles is a good road test. It does good around town, no issues at all. fluid pressure is right where it should be as well. shifts great compared to the old 4l80e.
