4l60e help
Can anyone tell me if 94 95 4l60e cases are interchangeable. I dropped my 94 4l60e and cracked the case. I have all new parts to build it but i obviously cant use the 94 case. I found a 95 4l60e that i can get for $100 if the case will work. I know the 95 has the pwm pump, which is why im asking. I dont know if there are any case diferences as far as pwm goes. Thanks, Ken
Can you run a 95 computer with a 94 4L60E ? My son has a 94 trans am LT1 we are putting a built LT1 383 motor out of a 95 camaro in it it came with computer and wire harness for the 95 but we want to use his trans from the 94 will this work?
Yes, modifications can be made to work.
However, an untuned/ unmodified 1995 PCM, will not simply work completely with a stock 1994 Core.
The most simply way to achieve this without having to modify anything on your own...
Would to directly swap over Parts from the 1995 Transmission into the 1994 Transmission.
The 1994 Core would need the following Parts from the 1995 Core:
-Both Pump Halves.
-Valve-Body.
-Separator-Plate and Gaskets.
-Internal Wiring-Harness and TCC PWM Solenoid.
Use the 1995 PCM and Wiring-Harness to connect to the 1994 Core.
How can you tell what year computer you have just having the computer not the car {We do not have the car that the computer came out of we were just told it was in a 95 camaro Don't know if it was original the computer we have says remanufactured} Thanks for the help.
