TH400 for my Honda S2000
Old Apr 18, 2016 | 12:32 PM
herecomesboost's Avatar
Default TH400 for my Honda S2000
I've decided to ditch the 6 speed in favor of an automatic. I already have the bellhousing adapter plate as well as a custom flexplate (that allows me to reuse my stock flywheel). I'm relatively new to automatics, however, so I'm looking for advice. The car is mostly street driven (90% of the time), but will see some time at the drag strip. Looking for recommendations regarding the size/stall of the torque converter? Transbrake worth it (since it's mostly a street car)? Any favorite/highly regarded company? Specs below in an effort to get the most applicable responses. Thanks in advance!
2.2 litre (87mm x 90mm)...30psi...750rwhp...8800rpm redline...6500rpm 2step...Ford 8.8 rear (3.89 FD)
Old Apr 30, 2016 | 12:28 PM
john kilgore's Avatar
are you sure you want to use a motor home trans on that low torque motor
Old May 24, 2016 | 09:03 PM
500 lb-ft is low? I'm open to suggestions (350)?
Old May 25, 2016 | 05:15 PM
crowstyle's Avatar
I commonly see people using a 3500 stall. There are so much brands to choose from since the th400 is so highly supported.
Old May 26, 2016 | 09:42 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Cant beat a solid FTI converter! Check out our online build sheet and lets get you a converter custom designed for your application!
ftiperformance.com/build-sheet
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 26, 2016 | 10:27 AM
weeble1's Avatar
^I second FTI converters. I love mine... even though I never got my t-shirt from you guys. haha.
OP, I see you are pretty close to me. I'm in Fredericksburg.
Old May 26, 2016 | 12:29 PM
LS1Tech Sponsor
Give us a call we'll get one sent out for you!
__________________
1-866-726-8358
FTIPerformance.com
