Problems after rebuild.
I put a decent size cam in the motor and did not swap out my torque converter because summit sent me the wrong one. That's a long story.. Anyways, I was planning on swapping out the converters but I decided to break the car in on the stock converter. After about 2 weeks of driving on the fresh built trans, it will shift through 1st and 2nd just fine but in 3rd it won't engage til around 4k rpm. But it does go into 3rd. It will not shift into 4th though. Is my converter toast or is it the trans?
Many local (non-chain) trans shops will hook those up and test at little or no charge.
If your trans works well/strong in any gear, then you can be pretty sure the converter is fine.
People generally post the pressure values in Park, Reverse, Drive and when blipping the throttle. Perhaps you are an experience builder who knows those values, but we have no way of knowing that. Also, more information helps future readers fix/understand their problems.
