Converter to flexplate space
Old Apr 25, 2016 | 08:51 AM
Hypforlife32's Avatar
Default Converter to flexplate space
whats up guys i installed a th400 in my f body, i have a question about the space in betweem. I have about .200-.218 space in between converter and plate. I can fit a 7/32 drill bit inbetween the pad and converter. I used .60 7/16 shims and used two of them. I am roughly .080 in converter space. IS this to tight is my question? I can Remove on washed and be like .140ish on the converter space. Let me know what the best way to do this is.
Old Apr 25, 2016 | 09:35 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
I would remove one washer. You want to be between 1/8"(.125") and 3/16"(.187) spacing before pulling the converter out of the pump.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 25, 2016 | 10:14 AM
Circle-D's Avatar
I agree, just use one shim. Also since you have the th400, make sure the converter pilot is engaging in the crank correctly. Either the converter needs to be built for an LS motor or you can use a pilot extender.
Chris
Old Apr 25, 2016 | 12:12 PM
Chris
Thanks for your help. I will remove the shim and yes it was built for a th400 to LS conversion. it has the extended pilot on the converter! Thanks.
