th350 has reverse no forward gear
Old Apr 25, 2016 | 09:38 AM
lance8693's Avatar
Default th350 has reverse no forward gear
Well I installed a 3500 stall converter and a fairbank shift kit .I also change the boost valve to the sonnax one because when installing the shift kit I damaged the stock one.Well I was leaving out for a test drive and have it a little gas it revved and finally shifted ,While driving it I would nail the pedal it would rev really high and finally shift.I pull up at a store and check the fluid levels they're fine I put in 8.5 qts.I stop the engine start it back up an now I don't have drive.When putting back in gear it goes into reverse great when I move to neutral it's seems like it wants to engage .I m lost.....could it be the valve body shift linkage?
Old Apr 25, 2016 | 11:38 AM
lance8693's Avatar
Fluid looks good no burnt smell
Old Apr 25, 2016 | 02:20 PM
bbond105's Avatar
I’m not familiar with the Fairbanks shift kit, but I would say that if the trans was working before the shift kit was installed, that a mistake was made while installing the shift kit. It is also possible that a shift valve stuck after that first shift. Check that the modulator valve has a good flow of manifold vacuum going to it.
Old Apr 27, 2016 | 07:44 PM
lance8693's Avatar
Imma pull the pan and check everything because I have reverse in 2 gears .In reverse and 1st
