th 400 swap, m6 program, how to eliminate skip shift code
Old May 6, 2016 | 12:33 PM
gd1996's Avatar
Default th 400 swap, m6 program, how to eliminate skip shift code
I swapped to a th400 after my 4l60e lost 3rd and 4th gear... had the pcm programmed for an m6 tune and I am getting a code for the skip shift solenoid. I don't know if it wasn't programmed out or what. I figured use a resistor in to bypass it, so I don't have to send my pcm out and spend another 30 on shipping... anyways can anyone tell me which pins I need to put the resistor through? I looked and it seems like 34/40 are the pins related to this, but one says it's for the light on the cluster... so not sure if that'd be the correct one, thanks! I need to get my check engine light out so I can pass emissions.
