4l80e Yoke options
Im after some advice/recommendations.
i am putting an LQ4 with a 4l80e into a GMT400 (2wd) but I am not sure what to do with regards to the Yoke.
I tried to fit the yoke i have but it doesn't seem to go in very far. so i removed the extension housing to take a look as i discovered there is different tail shafts.
Apparently the yoke i have is a slip yoke for 1410 UJ's
But it wont go in very far. (it bounces for the lack of a better term, doesnt go clunk as if it were hitting something)
The output shaft is splined all the way by the looks of it.
My question is:
Can i make this yoke work? or do i need to find a Fixed bolt on yoke? (may be difficult here in the UK)
I have no preference at the moment because i currently have no drive shaft, so i can incorporate a slip joint into the shaft when i have that made.
Thanks,
Jamie R.
2k Ta
a lot of the big GM trucks ive seen have that 1410 style u joint, and a slip yoke in the trans AND a 2 piece driveshaft (carrier bearing and rear slip-joint)
in fact I just cut one up to make my driveshaft
