help gap between flexplate and torque converter
Old May 9, 2016 | 07:25 AM
Camaro70ls2's Avatar
Default help gap between flexplate and torque converter
Hi guys need little help i have lq9 motor 2003 from sierra and 4l80E from isuzu 2005.the flex plate came with transmission had already spacer.my question is how much gap there should be between the flexplate and torque converter?i am have 1/4 gap... can i cover it will grade 8 washer or i dont need it?
Old May 9, 2016 | 08:05 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
With the converter all the way in the transmission, and the transmission all the way up to the block,Your converter spacing should to be between 1/8"(.125) and 3/16"(.187) before pulling it out of the pump for proper installation.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 9, 2016 | 08:11 AM
mrvedit's Avatar
Moderator
1/4" is too much as the converter will be partially pulled out of hte trans' pump rotor.
1/8" is perfect with a margin of +/- 1/16" - so between 1/16" and 3/16".
Drill bits make it easy to measure the gap.
If you don't have special converter washers, grade 8 washer are fine. If you have calipers, measure 3 matching ones within .002. You want them matching so that the flexplate isn't twisted and the weight matches too. Typical thickness is .090 which will bring you into spec just under 3/16".
Old May 9, 2016 | 08:12 AM
mrvedit's Avatar
Moderator
And you got two simultaneous answers within 40 minutes of your original post.
And I agree that 1/16" is a bit on the tight side; I would also aim for 1/8 to 3/16".
Old May 10, 2016 | 07:59 AM
thanks alot guys will get the washers between the gaps.
have a good day
