Turbo 400
Chris
TH400 (reverse manual with transbrake)
9 inch stall converter (you choose what stall) Mine stalls at around 4300 rpm.
Ultra Bellhousing (SFI Approved)
B&M Tranny cooler with AeroQuip fittings (28K GVW)
Braided tranny lines
Nitrous Prepped Driveshaft-Aluminium
M6 Crossmember (Not needed if you have an M6)
Locking Dipstick
In addition I had to purchase:
(1) case of B&M Trick Shift ATF Fluid
TH400 Tranny mount/30 washers to shim the tranny mount
TCI Flexplate (SFI Approved)
10 gauge wire for the tranzbrake button
An A3 Shifter (I used a Cheetah SCS Gated Shifter)
Spohn Torque Arm w/drive shaft loops (you no longer have a torque arm mount with a TH400)
ARP Flexplate/Flywheel bolts---Jegs has them, and I highly recommend them.
Autometer Tranny Temp Gauge
Plan on spending $3500-$4000 if you want to do it right.
