Question regarding internal trans temp sensor on 80e swap.
Old May 27, 2016 | 01:54 PM
weeble1's Avatar
Default Question regarding internal trans temp sensor on 80e swap.
Got the 80e swap done in my 99 T/A. I'm going to pick up an interceptor gauge mainly for water temp and trans temp. I used the "Frost" 80e conversion harness for the swap. Will this adapter harness read the internal temp sensor in the 80e as the stock harness would for the 60e? Just don't want to for out the coin for this gauge if it won't read the trans temp as that is the main reason for purchasing it. Thanks in advance.
Old May 27, 2016 | 09:46 PM
clinebarger's Avatar
60E & 80E Temp Sensors are both "Scaled" the same. So if the gauge works on a 60E it will work on a 80E.
Old May 27, 2016 | 10:01 PM
weeble1's Avatar
Ok great. I was mainly concerned with any pinout changes with the swap harness but after reading up, I think it's good from that aspect, too. Thanks.
