Reinstalling trans
Old Jun 6, 2016 | 10:51 PM
LS1-Mike's Avatar
Default Reinstalling trans
Installing the trans back in my 01 ss after installing tc and having a hell of a time getting the dipstick tube back in. Wondering if I cut a little off the end that goes into the trans if that will throw off my dipstick readings.
Any thoughts or suggestions?
Thanjs
Old Jun 6, 2016 | 10:53 PM
Mappinsj's Avatar
It should not affect your readings if it goes down until it hits the bump stop. But something is stopping it from reaching correctly and I would consider making more effort into finding what is stopping it from hitting the mark.
Old Jun 6, 2016 | 10:56 PM
98CayenneT/A's Avatar
Thanjs
Is the dip stick tube loose where it bolts up top?
Old Jun 6, 2016 | 11:01 PM
LS1-Mike's Avatar
Yeah the bolt on the bracket is completely out.
Loosen that top bolt a bit to give ya more movement with the dip stick tube. Then I usually put the transmission on a floor jack and aim the dipstick as I'm jacking the transmission up and it will bend right on in there
Old Jun 6, 2016 | 11:08 PM
I usually leave that bolt in but loose, then aim and jack the transmission up and it will slide right in
