4L60e swap takes off in 2ND
Old Jul 12, 2016 | 08:30 AM
rlane5's Avatar
Default 4L60e swap takes off in 2ND
I did a LQ4 swap with 95 4L60E and 0411 PCM. The trans starts in 2nd gear, but when I pull it in 1st manually it will go in 1st, and when shifted it will go into 2nd. I was told it may be the PWM, not letting it drop into 1st gear. Have anyone had this problem.
Randy
Old Jul 12, 2016 | 10:59 AM
01ssreda4's Avatar
Any fault codes?
Old Jul 13, 2016 | 07:07 AM
rlane5's Avatar
No transmission codes, but I do have MAF and #7 cyl misfire
Randy
Old Jul 13, 2016 | 07:29 AM
Jeremy@RPMTransmissions's Avatar
Sounds like it is in limp mode. Fix your MAF and misfire issues asap and that should get you out of limp mode.
