Pump Seal
Old Jul 21, 2016 | 07:34 PM
98 Z28's Avatar
Default Pump Seal
Is the pump seal something that needs changed when putting in a new torque converter or any other seals/o rings during the install?
Old Jul 22, 2016 | 12:11 AM
Cpt.Derrek's Avatar
nope, just need the input shaft seal.
Old Jul 22, 2016 | 11:07 PM
98 Z28's Avatar
The actual seal needs swapped out or is it just the o ring? Why is no one ever says this when upgrading a torque converter?
Old Jul 23, 2016 | 12:19 AM
Cpt.Derrek's Avatar
sorry just the O-ring. And it really isn't completely necessary since that O-ring is probably fine, but since you're there and its cheap and easy to do.
Old Jul 23, 2016 | 08:57 AM
Jays_SSZ28's Avatar
And the seal isn't cheap and easy to do? The seal can be found at any auto parts store, good luck finding the correct orange/brown o-ring LOCALLY.
Seal.
O-Ring, left.
