4l60e transmission
You need to make sure that the 4L60E out of the 02 4.3 has a 300mm input shaft and not the older 298mm shaft. The LS engine vehicles all had/need the 300mm shaft and I have been told that GM switched later non-LS engines to the 300mm too.
