What is wrong with my 4L60?
Old Sep 19, 2016 | 06:52 AM
ragtopz28's Avatar
Default What is wrong with my 4L60?
I bought a used Performabuilt LV2 trans, installed (w/3800 converter) and it was working great for about 10 1/8 mile passes. Now reverse is binding so bad it will stall the engine, no neutral (tires spin forward when in neutral) and 1- 4 seem fine. I first was hoping it was a cable alignment/adjustment...but after putting it on my lift it does the same thing, (disconnected cable) when shifting lever by hand, car idling on the lift. Park to reverse= tires rotate about two turns and binds up. Reverse to neutral=tires start to spin forward. And 0D, D, 2, to 1st downshifts normal.
Clutches? or Worse?
It is the 1998 in sig.
Old Sep 19, 2016 | 08:40 PM
clinebarger's Avatar
The Forward Clutch is stuck "on". Whether it's Mechanical or Hydraulic is the question. I would pull it & find out what went wrong.
