Traction Control vs Torque Management
Old Jun 21, 2004 | 07:32 AM
UKDriver's Avatar
Question Traction Control vs Torque Management
Current set up
1999 A4. Carroll stage 1 supercharger, Raptor 700 transmission rebuild, 2300 stall TC, Donaldson filter, Borla exhaust, R Zimmer tune (for the supercharger only), LS1 Edit.
Problem
Kicks into abuse mode and pulls timing limiting RPM to 3,000.
Attempted solution
Turned off torque management with LS1 Edit, increased abude mode RPM to 6,000 and TPS% to 50. Did not change line pressure.
Still pulling timing at 3,000 RPM.
Solution
Turn off traction control on console, all problems disappear! (apart from orange light on dashboard)
Question
There appears to be no way to amend the traction control in LS1 Edit - is this correct?
Why does traction control override torque management?
