4wd to 2wd
The problem with an older transmission is that this disassembly is likely to damage the old teflon sealing rings on the pump and input shaft. These take time to replace. And with the input shaft out, you might as well replace the 3/4 clutch. Etc, etc. It is a slippery slope to a complete rebuild.
