Trans cooler
Old Sep 27, 2016 | 01:38 AM
pozesd99''s Avatar
Default Trans cooler
Does an a4 1998 z28 come stock with a trans cooler mounted infront of the radiator or is it aftermarket
Old Sep 27, 2016 | 12:09 PM
pozesd99''s Avatar
?? Nobody?
Old Sep 27, 2016 | 12:19 PM
98CayenneT/A's Avatar
It is aftermarket. The stock tranny cooler runs threw the radiator.
Running a larger aftermarket cooler in front of the radiator and bypassing the stock cooler in the radiator will drastically drop your transmission temps
Old Sep 27, 2016 | 12:22 PM
Post #11 in this thread is a good setup
https://ls1tech.com/forums/automatic...l#post19397181
Old Sep 28, 2016 | 04:31 PM
mrvedit's Avatar
Moderator
And reduce the chance of your 18 year old radiator springing a leak on the internal trans cooling line and ruining your trans by filling it with coolant.
