4L80E reubuild kit
I was looking at rebuilt kits for a 4L80E. Any thoughts on his one?
https://transpartswarehouse.com/auto...t-1997-up.html
Is this what your looking at? Your link doesn't work.
I don't care for Alto Frictions, Even though the one's in the link appear to be High Energy. If your going to use Molded Steel Pistons....The old one's are probably OK. The Filter in the link is probably Chinese junk (Use SPX-Filtran). The Bushings are most likely SAP(Seal Aftermarket Products) off shore junk, I prefer Clevite or Federal Mogul.
Stick with Borg Warner or Raybestos, You can buy a Master Overhaul Kit from a Transmission Wholeseller like Transtar, Or WIT with a Friction Module of your choosing. Or a Vendor can probably hook you up??
Borg Warner Part# in the right hand corner....
