flexplate ?'s regarding weight, runout, etc.
I'm also interested in runout. The meziere is supposed to be between 0.003-0.005".
I'm obviously not looking at the cheapest flex plates made. I don't know much about the circle d or reactor flex plates. Any advanced knowledge on any of these and/or lighter or heavier flex plates?
Since the flexplate bolts to the much, much heavier torque converter, the weight of the flexplate is a non-issue performance wise. If you want max driveline acceleration, you would choose a small diameter (higher stall) converter, as they are lighter.
However there is research showing that too-light a balancer (and perhaps a converter) lead to more crankshaft vibration/harmonics which in turn can upset the valve train for a loss of power at high RPM. While I have no 1st hand info on this, "lighter" is not automatically better.
