6L80e, rough/delayed downshifts
Old Dec 2, 2016 | 08:01 AM
jrobie79's Avatar
Default 6L80e, rough/delayed downshifts
background:
Been lurking here for awhile, just purchased a 2011 escalade, went through and changed all my fluids so I had a baseline. Transfer case fluid had no semblance of red coloring whatsoever when I changed it, so I'm wondering if it was too late.
Tranny fluid was dark red, didn't smell burnt, and carfax showed that it was changed at 70K miles. Car currently has 140K.
I changed the transmission filter, then flushed the fluid via the clear hose in the radiator cooler port method, ended up using 12 quarts in all, filled it, drove it, and checked and added as necessary.
I have a significant back road commute to work, and I've been noticing as I'm coming to a stop or near stop, the transmission (I assume, maybe transfer case?) is clunking/hard shifting down, banging into a lower gear, noticeably so. It doesn't happen all the time, but often enough to be concerned. I don't seem to notice anything out of the ordinary when it upshifts though, when I punch it, it seems to shift firmly and smoothly through all gears.
I've checked and double checked the fluid level, but I'm starting to wonder if the lack of maintenance from the PO might require a rebuild.
Thoughts?
Old Dec 4, 2016 | 08:20 AM
mrvedit's Avatar
Moderator
Since there are only a few people here knowledgeable about the 6L80E, you might want to post your question on e.g. the Pontiac G8 or Camaro5 forums.
Old Dec 4, 2016 | 08:33 AM
topless2002SS's Avatar
This is a major complaint for most 6L owners in the truck forums, and not a issue per GM, it is in the programing they use to try and hold the trans in the highest gear possible for fuel mileage.
Old Dec 5, 2016 | 08:53 PM
MY_2K_Z's Avatar
I have a friend that is the transmission tech at a Chevy dealer and he deals with this on a regular basis. There is a procedure to fix it. He has to flash the computer with his tech 2 then takes it on a drive to get the trans to relearn the proper Shift points or something. He does these everyday as it is very common issue.
Old Dec 20, 2016 | 03:42 PM
jrobie79's Avatar
Will a dealer charge to perform this or is it something that's known and is offered free? I have looked, but haven't seen any service bulletins associated with it.
Old Dec 20, 2016 | 07:00 PM
MY_2K_Z's Avatar
The dealer I work at does it as a warranty claim. I'm not sure if there is a tsb on it
