4l80e late 2nd gear
so i did a quick log of gear and some tstates and it is commanding the shift at the right time, and the solenoids appear to do what they're supposed to. Solenoid A turns off as soon as gear 2 is commanded, but then it takes 0.7 seconds/1100rpm in this one specific case for the rpm drop to take place.
all of my shift times are zeroed out.
is there something i can do to make this more immediate? the shifts always feel very firm, there is no indication of slipping. I used Jake's valve body plate and instructions and normal driving it seems to do exactly what its supposed to.
usually it doesn't shift until it bangs the rev limit at 7200 which may or may not be ok but its a little nerve racking.
thanks for any input.
I guess these new electronically controlled transmission just have a lot more volume to move around to apply gears?
are the manual valve body 4l80es quicker to react?
