99 to 03
Old Apr 7, 2017 | 03:17 AM
zer0_rwtf's Avatar
Default 99 to 03
I have a 03 tahoe with a 5.3 and 4l60e I am looking to put a new tranny in it. I found a 4l60e out of a 99 sierra with a 5.3. I have been searching for the past few hours for a definitive answer as to if I can use the 99 in my 03 without any changes or not. Any help would be appreciated thanks.
Old Apr 7, 2017 | 03:38 AM
98CayenneT/A's Avatar
As long as it's a 2wd 4l60e going into a 2wd truck or 4wd going into a 4wd truck it will be a direct swap.
Converting a 4wd 4l60e to a 2wd 4l60e would require a output shaft and tail shaft swap.
Old Apr 7, 2017 | 04:23 AM
zer0_rwtf's Avatar
It is a 4wd going to a 4wd, only difference is its a 99 sierra and what its going into is an 03 tahoe. So the electronics will work? No worry on a spacer or shaft difference?
Old Apr 7, 2017 | 04:56 AM
Yes sir, identical, as long as it's 2wd to 2wd or 4wd to 4wd you are good to go.
1998 to 2007/2008 4l60e/4l65e are compatible. Some internal changes on the later years but nothing that would hinder say putting a 2006 or what not in there. Unplug round harness, out with junk tranny, in with new, plug in harness and go.
Old Apr 7, 2017 | 05:28 AM
zer0_rwtf's Avatar
Thank you so much!
