transmiossion removal
Old Apr 8, 2017 | 11:10 PM
batman55066's Avatar
Angry transmiossion removal
Working from under the vehicle. Im having trouble removing the transmission along with the transfer case from 2003 suburban. Any suggestions?
Old Apr 8, 2017 | 11:17 PM
98CayenneT/A's Avatar
What's the problem? Does the transmission not want to separate from the block/off the dowls ?
Old Apr 9, 2017 | 01:44 PM
yes. transmission wont drop. Do I need to disconnect the transfer case?
Old Apr 9, 2017 | 03:04 PM
2ToeRacing's Avatar
yes, you'll need to remove the transfer case. Did you remove all the bell bolts? there's six counting the one at the very top of the bell housing. Sometimes there hard to to get off the motor.
Old Apr 9, 2017 | 03:08 PM
01ssreda4's Avatar
I pulled my transfer case first on my yukon, seemed easier to me that way.
Old Apr 11, 2017 | 02:35 AM
07NBSChevy's Avatar
The dowels can be a major pain as well. I had to pry between the trans and engine while "jiggling" the trans to separate mine. I left the T-Case on on mine, then again..the NNBS might have more room underneath were the T-Case does not cause issues with removal.
