1999 4L60E 2-3 accumulator
Old May 3, 2017 | 07:24 AM
Buckdaddy's Avatar
Default 1999 4L60E 2-3 accumulator
I'm wondering if I should replace the 2-3 accumulator ball and case. I did the leak test with 50/50 trans fluid and mineral spirits...it leaked very little after several minutes so I'm trying to determine if it needs replaced. My first rebuild, 3-4 clutch pack burnt!
Old May 3, 2017 | 07:27 AM
Buckdaddy's Avatar
Default I forgot to mention...
Sorry, It's a 1999 4L60E!
Old May 3, 2017 | 07:40 AM
faribran's Avatar
When in doubt I change it.
Old May 3, 2017 | 12:18 PM
bbond105's Avatar
I doubt that is your problem. Check for leaks where the input shaft presses into the input drum. I attach instructions for a Sonnax Sure Cure® Kit. The last few pages give instructions on how to air check the pump and input drum.
File Type: pdf
Old May 4, 2017 | 07:34 PM
clinebarger's Avatar
That a long flat end punch & seat the check ball with a light tap....This should fix any small leakage.
