2005 escalade transmission
is the transmission useable at a reasonable price to convert to rwd? if it is, home mechanic type of job.
thanks
Pull the Pump, 4th/2nd Servo, Lift the Band off the Anchor, Remove Input Drum/Reverse Input Drum, Remove the snap ring holding the Output shaft.
Reverse the order to reinstall except install the band after the Input Drum/Reverse Input Drum is installed.
