LS3/4L80 into a Ford
I'd like to keep the RPM's down in the 2200 range at 70 mph, the rear end has 5.00's in it. I've yet to order my converter but I'm thinking below 2600 stall to keep the heat down
Any help would be appreciated
I just swapped an 80e into my 454 crew cab dually. With a 4.10 year and 31 inch tires im turning in the 2300/2400 range to run it at 70mph. I'm running a stock converter and the rpm drop from lock to unlock is close to 300rpm on highway
