Which way for the 4l60e the force motor connector
Old Jun 10, 2017 | 02:34 AM
SMaXMan121's Avatar
Default Which way for the 4l60e the force motor connector
hi all
I need some quick help.
With the force motor connector for the 4l60e is there a right or wrong orinetation?
the images I found show the red of the 2 wires on top. Red = power.
the force motor doesn’t indicate polarity.
Strangely mine goes on easy the other way.
Thanks a head of time
Attached Thumbnails Which way for the 4l60e the force motor connector-force.png   Which way for the 4l60e the force motor connector-acu-24220158.jpg
Old Jun 10, 2017 | 09:01 AM
Neutron Star's Avatar
According to this polarity doesn't matter. http://www.fitzall.com/cmsAdmin/uplo...tion-sheet.pdf
Old Jun 10, 2017 | 11:16 AM
SMaXMan121's Avatar
its a different force motor
Old Jun 10, 2017 | 11:21 AM
SMaXMan121's Avatar
atra manual force motor image has a different color
Attached Thumbnails Which way for the 4l60e the force motor connector-pcs-atra.png
Old Jun 10, 2017 | 01:07 PM
Good observation, I didn't realize it was an aftermarket part.
Mike
Old Jun 10, 2017 | 07:19 PM
clinebarger's Avatar
The force motor connector has a lock on it, Lock faces the force motor.
Old Jun 10, 2017 | 09:10 PM
SMaXMan121's Avatar
not the after market ones.
this is the aftermarket one with flat lines cast into the connector
Attached Thumbnails Which way for the 4l60e the force motor connector-zoomed-pcs-atra.png
Old Jun 11, 2017 | 02:28 AM
SMaXMan121's Avatar
i found the answer and wanted to share it.
Attached Thumbnails Which way for the 4l60e the force motor connector-connector-orientation.jpg   Which way for the 4l60e the force motor connector-curciut-diagrams.png
Old Oct 15, 2018 | 02:18 PM
blak_ls1's Avatar
would it be the same for 4l80e?
