Adjustable transmission mounts
Old Jun 21, 2017 | 09:32 PM
White 02 WS6's Avatar
Default Adjustable transmission mounts
Has anyone ever used these adjustable tranny mounts:
https://crossmembers.com/product/adj...-applications/
My nova originally had a turbo 350/crossmember and I have a 4l80e in it now. The 4l80e is of course longer than the 350 and I was wanting to make some kind of adapter to make the tranny fit with out changing the crossmember. Anyone had any luck with this product?
Old Jun 21, 2017 | 09:51 PM
wht/73's Avatar
Don't buy one. I should have done this.
Much cheaper and you can put it where you want!
Cut yours in 3 pcs and weld a plate between them.
Attached Thumbnails Adjustable transmission mounts-modified-xrossmember-80e.jpg
Old Jun 21, 2017 | 10:30 PM
I don't really want to cut up my stock crossmember. The adjustable one is only $100
Old Jun 21, 2017 | 10:35 PM
wht/73's Avatar
That's cool. I used a G force.
Sits way to low. Had to use a Tall mount to keep my small distributor from hitting the firewall.
$289 and I had to buy a mount then put a 1/4" spacer under it.
I still may do mine like the picture.
It would be 20lbs lighter!
Old Jun 21, 2017 | 10:42 PM
Nice. I will have to give them a call tomorrow and see what they say about it. Thank you for the help...Anyone else use this?
