TH400 only reverse...
Had the car on the dyno some weeks ago and drove it home with no issues. Had the car parked until now as I had a PS pump failure, but fixed it and should take drive. I put the car in reverse and drove out of the garage and put it into low, but no forward movement. It was a little low on fluid, but topped it up, but still the same. With a pretty high rpm, the car barely moved into the garage again...
Drained the fluid, it looked pretty ok and I could not smell anything burnt...
Any suggestions where to starts?
Thank.
Thank.
Anyway I picked up a newly built TH400 with shiftkit today from the local transguy. Should be up and going pretty soon I hope
Thanks
